Unofficial Allis Homepage
Turbos for 2900 series engines
Hudsonator View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Topic: Turbos for 2900 series engines
    Posted: 11 Jul 2012 at 9:24pm
I recently purchased my first "numbered" Allis - a 185.  It has a turbo on it about the size of my fist, and spools up to a pronounced scream just off idle - with no load.  Its a retro-fit, but has been on the tractor since new in 1978.  The local dealer would install them for the customer.  The turbine housing has been HOT in its day and has some severe signs of heat stress.
My questions would be: what turbos were original to the 2900 series engines?  What are the specs for those?  And, what would be a good replacement?
I'd like to pull about 110hp out of this tractor for pto work - but will never get close to using that much on the drawbar.
I've done alot of things in life, but never messed with a turbocharger.  I need some Allis-related education in this area.
There isn't much a WC can't do.
WD's just do it better.
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 9:26pm
Just get one from a 200 AC.
WD45 View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 9:30pm
Had an engine kit installed in our 185 last year with turbo then  they dynoed the new engine for 30 min. @ 92 hp.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 FORK LIFT.716H and 1920H
CAL(KS) View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 9:31pm
probably one of these two, the Airesearch is more common i think.  was installed on these tractors and combines
D19, 190, 190XT, 200, 7000, 7010, 7020, 8010, L, L2, L3, M, M2, M2R, M3
Airesearch T04B80
Rayjay-Thompson 370F70
Me - U,UC,WC,190XT,TL-12, 145T,HD16
Dad- WD, D17D, D19D, RT100A, 7020, 7080,7580, 2-8550's, R62, R72 HD15
DSeries4 View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 9:40pm
My series I 190 XT has a Rayjay turbo on it.  Don't know much more than that though.
'49 G, '54 WD45, '57 WD45 '58 D14, '59 D14, '61 D15d, '66 D15II, '67 D17IV, '67 D17IVd, '67 190XTD, '73 620, '77 175, '85 6080
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hudsonator Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2012 at 10:18pm
Do any of you guys know about what boost pressure the stock turbo would put out?
