Unofficial Allis Homepage
Terra tiger repair
Henry se/k! View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Topic: Terra tiger repair
    Posted: 26 Apr 2013 at 7:06pm
Started working on my terra tiger serial no 2681. The lert front axle sprocket spins on axle shaft.Could some one tell me about pin, key, or what ever makes this turn? Can't see down in there very good, and do not want to remove complete shaft if I do not have too.
farmtoybuilder View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2013 at 7:53am
You will need a need new 5/16" X 2" solid grooved pin. Use a 1/4" -5/16" pin punch if any old one is in axle still?  Use punch to align and drive new pin in place. Front ones are a bear to work on. Unhappy  We have pins in stock if you need them. Most older machines have ware in sprocket holes and even in axle holes. If pin fits tight in axle it will run with loose sprocket holes. If pin doesn't fit tight in axle then you could used longer bolt and nut and peen over end. Excess treads would need cut off also.
Edited by farmtoybuilder - 27 Apr 2013 at 7:55am
