Unofficial Allis Homepage
model 302 baler
Bolivar Boy View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Topic: model 302 baler
    Posted: 13 Oct 2012 at 4:30pm
found an ac 302 square baler. very low useage. housed. dry. hasnt been used in 10 years. any advice on this baler? would be doing 10 to 15 acres a year of straw or hay. Value? thanks in advance.........tp studer. wooster,ohio.
Flint23 View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2012 at 1:29am
The 302 is a good baler, I've used mine to bale 500 to 700 bales a year for the past 5 years. Since it's been barn kept, it should be in good shape to bale. you can trip the knotter and turn the fly wheel (turn the direction of arrow on flywheel) to see if the knotters work and if the ram moves smoothly. Check bill hooks for wear. Check resister plates for wear. Not sure on value but I would guess around $700.00 to $1500.00 . HTH
been there done that, not doing it again...
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2012 at 1:44am
  Here's a pic. of my 302 baling hay with  my son-in-law's JD 620
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flint23 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2012 at 1:56am
see if this works
Jim Lindemood View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2012 at 6:55am
Agree - with Flint.
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2012 at 9:09am
do the old ac square balers use a new holland knotter?
Ky.Allis View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2012 at 12:48pm
My AC 444 baler has knotters that seem to be exactly like New Holland. In fact it has a complete NH knotter on one side. I broke a chunk out of the knotter frame while driving a roll pin out to remove bill hook. I had 2 extra NH knotters that had just been gone thru and was an exact fit. Works perfect
