pulling tires
one54dodgetruck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote one54dodgetruck Quote  Post ReplyReply Direct Link To This Post Topic: pulling tires
    Posted: 24 Oct 2014 at 4:50pm
has anyone ever tried cutting diamond tread tires for pulling? I'm thinking cutting each diamond into a "V". Any experience?
2 WDs
B
B112
D14
D15
185
7040 pd
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2014 at 5:47pm
I'm just thinking while I'm typing, but one of the things you want puling tires to do is "clean" (get the loose dirt away from the tire). I'm thinking a "V" cut on each diamond would lead to a lot of loose dirt staying under the tires.
I could very well be wrong, but that's just my 2 cents...
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2014 at 7:21pm
Did you ever see a 1st place puller with turf tires ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2014 at 9:30pm
There always has to be someone to try it first. I have seen brand new tires run backwards on winning tractors. But that was years ago in a farm tractor class. I also saw a W9 with an earthmover tire on on side and a regular tractor tire on the other, the tractor tire spun first. I've been giving a lot of thought to the same idea lately myself. 18.4X16.1 tires in R-1 tread are hard to come by, but the diamond treads are plentiful. I wasn't thinking of doing each diamond in a V-cut, but doing a V-cut across the entire tire.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2014 at 5:18pm
Great to see Paul B on this Pulling Forum
    Tires? What is a body to do? I thought I had my CA set up in 3500 competition stock class weighted up with water and wheel weights running 13-6 24 Firestones.
    I got the suprize of my life when a 24 year old showed up with a weighted up bone stock SFW CA with what looked like 11-2 BFG rock hard ragged rubber as old as the tractor and out pulled me easy by 24 feet.
    The clay track was exceptionally dry and hard as concrete. So hard that my rubber left black smeers where I spun out early.
    Are the biggest 24s you can fit on your rims better than what Allis thought was big enough?.
    This kids CA was not the only one to out pull me. I ended up 4th out of 6 in the class. Third was a D14 running 26in combine wheels and big wide tires.
    Weighted up to 4000 competitive the D17 got me by more than just a little bit.
    On this hard track the bigger tires spun faster than narrow rubber.
