Forklift Identification Assitance |
treeman
Bronze Level Joined: 22 Jul 2014 Location: phoenix az Points: 12 |
Posted: 29 Jul 2014 at 9:45pm |
I have a 1959/60 fork lift that I need some help identifying the engine in. I've been searching the web and can't find much to go on. The Load Capacity Chart on the fender says "500 Series Fork Lift". On the top of the mast is plate that says Model 614 serial #1073.
The marking on the side of the block are "AM4339-3" with a "2" below. Under where the carb is it appears to say "4C". The block has cracked and I need to identfy the engine so that can search for a suitable replacement. Any help would be great, thanks |
Mrgoodwrench
Orange Level Joined: 03 Apr 2011 Location: CHICORA PA Points: 2081 |
Pics would help
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
treeman
I will take some. The ones I have the file size are too big. Thanks, Paul
treeman
Edited by treeman - 31 Jul 2014 at 9:11am |
treeman
treeman
treeman
My son found this id plate. Not sure where it is located.
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50518 |
160 cu in gas motor, like in a D-15 series 2, or 175 cu in diesel, or 200 cube direct ignition diesel, in later models.
treeman
Thank you for the help
