WD45 VALVE ADJUSTMENT |
TBH64
Bronze Level Joined: 17 Feb 2010 Points: 3 |
Posted: 17 Feb 2010 at 8:52pm |
My first time rebuilding a WD45 and I need to adjust the valve gap. The manual gives me the gap "hot" but how do you do an initial adjustment cold? Then do I run the engine with the valve cover off or on to reset the gap hot? Can someone give me a step by step procedure on how to do this? Thanks. |
mlpankey
Orange Level Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
just adjust them to .014 cold you will be fine.
firebrick43
Orange Level Joined: 10 Dec 2009 Location: Warren County Points: 592 |
Take the valve cover off, and turn the engine over slowly(I like to take the spark plugs out and grab hold of the fan belt and pull up to turn the engine over. Watch the valves and see which ones are being activated as you see the push rod go up and then down and stop movement adjust that valve. Use the hot setting just to get close, tightening the screw until you feel a slight drag on the feeler gauge. Holding the center screw tighten the lock nut and move on to the next valve. Mark each rocker arm in some fashion so you don't miss one. It will take at least two full revolutions to complete this task. Set the valve cover back(contain mess), install the plugs, and fire it up. Don't rev it or anything, just run it till it gets in the green on the gauge. Remove valve cover and plugs(plugs removal just makes turning the engine over easy) and repeat. Button it back up, put the hood back on and have fun
Denis in MI
Orange Level Joined: 15 Sep 2009 Location: Norvell, MI Points: 832 |
you could adjust them with the engine running, I never tried it but saw it in a AC promotional video one time.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Charlie (NC)
Orange Level Joined: 12 Sep 2009 Location: Coastal NC Points: 942 |
I think Firebricks got it right. Just wear an old shirt when you adjust it running. You'll figure out why.
Chuck(ONT)
Orange Level Joined: 11 Sep 2009 Location: Ontario Points: 1055 |
I used to do my 56 Mercury with the engine running. What's the problem.
Orange Level Access Joined: 12 Sep 2009 Points: 19496 |
After you run it for an hr or two, retorque the head bolts the next morning (cold) and adjust all the valves to .015" COLD.
Charlie (NC)
Every Allis engine I've ever adjusted the valves on was very good at slinging droplets of oil in an arc about 3 feet above and to the sides of the tractor. Lot's of flow into the upper end of those engines and the rocker arms do a good job of slinging it. Your mileage may vary.
TBH64
Ok, Thanks guys. I adjusted them to .015 cold but I have not tried to start it yet. I just wanted to make sure that I had to put the valve cover on first then run it. This thing hasn't been run in over fifteen years so there was a lot I needed to do to it.
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22807 |
If you haven't done it already, replace the freeze plugs in top of the head. It's not good to have one spring a leak after doing a bunch of other work on the engine.
TBH64
I had that done when the head was rebuilt. Thanks.
Brian Jasper co. Ia
When I did my Oliver 60, (very similar engine design) the fan was the main problem blowing the oil all over, not so much the rockers slinging it around.
