Woods L59 mower blade removal
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Topic: Woods L59 mower blade removal
    Posted: 29 Mar 2012 at 7:52pm
I'm having a heck of a time getting the bolts loose that hold on the blades of a Woods L59 belly mower. Are they reverse or regular thread?
Does anyone have any suggestions on how to break them loose without ruining them, such as a torch?
Thanks.
LannyMTN View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote LannyMTN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 7:56pm
They are left hand, or as you call them reverse threads.
Lanny
wfmurray View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 7:59pm
Most thing like that and grinder and so on loosen in the direction of rotation.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 8:44pm
If you're still having problems later, I am coming up on Saturday.  I'll call you if you don't PM me back.
Post Options Post Options   Thanks (1) Thanks(1)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 10:04pm
I had a mower that had stuck nut on the blade, we heated it carfully with a torch and it broke loose.
Dick L View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 10:10pm
A six point socket will be your friend. Yes left hand threads.  Oh yes and a good impact wrench to put the six point socket on.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 10:16pm
Put a block of wood between the blade tip and the front shield. That is how I do it.Smile
KenBWisc View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 10:25am
After you get them loose and before re-installing use never seize on the threads.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Post Options Post Options   Thanks (1) Thanks(1)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 10:30am
If it is an L59, that L stands for left handed because the blades turn counter clockwise as you look down on the deck and it will have left handed threads. I do like Dick suggests, a 6  point impact socket and all ya gotta do is bump the trigger a couple times to remove the blade.
Edited by CTuckerNWIL - 30 Mar 2012 at 10:32am
B26240 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 12:08pm
Dick as usual is right on !! Ive taken of blades with a impact that I thot would never come loose having tried a 1/2 in. flex handle with no luck and then they come right off with the impact.
Greg_WJP_(WI) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (1) Thanks(1)   Quote Greg_WJP_(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 12:26pm
I put a block of wood (4x4), also, and a breaker bar.  Fortunately I've never had to pull out the impact tools.  And like Ken suggested, some type of anti-sieze is helpful.
Mowersden View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mowersden Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 6:30am
To remove the blade, you must turn the blade's retaining bolt to the left, or counterclockwise. Before undoing the blade, tip the mower on its side with the engine air cleaner facing up and block the blade with a piece of wood so it can't turn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 5:16pm
Wouldn't that be kinda hard to do, on a tractor mounted mower?Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 5:28pm
Maybe he has photos ??  I have not seen a B or C turned on its SIDE to remove the mower blades..... I WANT PHOTOS !! Wink
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 6:03pm
Miss Mowersden just joined the Forum, then posted.
Guess she didn't realize this is the 'Farm Tractor' section.
Welcome aboard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2020 at 9:00pm
Milwaukee 1/2” impact gun takes them right off. Left hand threads tend to tighten as the mower is used due to the direction the blade turns. Best tool I have purchased in many years. We run our CA up on ramps to get the necessary clearance to remove. L306 is just a bigger version of the L59.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 7:55am
"WRONG"
 The L59 mower deck commonly used on Allis tractors, has left handed threads, and needs to be turn clockwise, to remove.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 9:16am
Anybody else notice this thread is 8+ years old? OP hasn't checked in since June of this year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 11:34am
Tuck is correct Clap about the "CLOCKWISE" direction to get them off.  (The OPPOSITE of normal)
Mike, I noticed that because I helped Goose with this WAY BACK.
I also noticed that this "Mowersden" was ONLY ON here for 10 minutes and left a link.  Is this spam?  or is she for real?  We'll know the answer if she ever comes back.
Edited by Ted J - 21 Oct 2020 at 11:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2020 at 5:38pm
Methinks mowersden might be a scammer, 8yo post, his first post, don't know what we're talkin about...  He's buildin post #'s so's he can hit the site with spam ads...Wink
