Transmission Shift Cables |
Dale
Silver Level Joined: 11 Sep 2009 Location: Ontario Points: 372 |
Posted: 19 Mar 2012 at 6:40pm |
Has anyone ever tried to refurbish the shifter cables on the 7000 series tractors. Replaced one set with new ones but the old ones when straight weren't much different than new ones when straight. However, they are curved in a couple of places when installed and when compared when rolled in a circle-then quite a difference between new and old ones.
Any way to get the old ones to work good again or are they garbage. The dust caps at both ends look good. Anyone with any experience or ideas? |
Orange Blood
Have never tried it, but will tell you this, We have put far more hours on the new set that was installed many years ago vs. the originals, and have never replace a single one of them. The new Green cables are just so much better. I think what happens in the old ones, is the fine dirt gets in the cable and swells the center cable by working its way inside the cable during the push cycle, and then once swelled it doesn't move well since the clearance is gone.
Still in use:
Dale
Thanks for the post. Now I'm wondering about the new ones I bought. The ones I bought are for my 8550 which I consider a 7000 series. My old ones are black and so are the new ones. Are the new ones for the 7000-7080's green? Does anyone know if there are green cables for the 8550?
Adam Stratton
Orange Level Access Joined: 11 Sep 2009 Location: SW MO Points: 1363 |
I have had some luck by taking the cable out, moving the dust cap, squirting penetrating oil of your choice, then chucking it up in a drill. Spin, oil, spin, oil, until it moves freely again. Only seems to work if the cable just got stiff, if they are stretched, you are better off with a new one. I havent seen the green ones either though.
ALLISMAN32
Bronze Level Joined: 13 Mar 2011 Location: Hillsboro, IN Points: 199 |
I dont think all the new replacement cables are green. Alot of the tractors that spend all their time outside seem to have cable problems more frequently than ones that get to stay inside. If the new one you get lasts another 10 years or so you will probably have upgraded to something different by then for daily use and the AC will be a toy if not already one.
Russ-neia
Silver Level Joined: 11 Sep 2009 Location: NE Iowa Points: 489 |
The newer style green cables, and some of the black ones have a spiral-wound outer sheath, so the inner (moving) cable doesn't wedge/bind. The originals had the strands of the sheath parallel to the moving cable. As things wear, the inner and outer strands tend to bind.
Knowing this, lubrication is not likely to help much or for very long. There is a company called Cable Craft (a division of Tuthill) that makes these control cables and they sell direct. The ones I've gotten from AGCO even had their name on them. May as well cut out the middle man. Edited by Russ-neia - 19 Mar 2012 at 10:10pm |
The innovators offer what others will imitate.
Kevin in WA
Orange Level Access Joined: 08 Feb 2010 Location: Lynden, WA Points: 607 |
I think the green ones are also teflon lined.
Lonn
I did "redo" the hi/lo shift cable for my 7050 a few years ago. It got real stiff and unable to shift so I went and cut the end with the 5 or 6 inch steel tube. I only cut the tube. Removed the cable and cleaned out the sheath. Sanded down the cable. Spray with a real light oil. Slipped it together. Found a piece of tubing that just fit inside or outside the old tube I had cut (can't remember if it fit inside or outside) and brazed the old tube back together. It's been working great probably for 5 years or so. Funny how frugal one gets when you have no more cash.
Wink I am a Russian Bot |
