Starter |
MilesGray (CO/KS)
Orange Level Joined: 13 Sep 2009 Location: CO/KS Points: 729 |
Posted: 17 Dec 2011 at 8:51am |
Does an Allis B starter fit on a CA?
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy! |
Fred in Pa
Orange Level Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9101 |
What year ,B
MilesGray (CO/KS)
1938 - 40. I have about 10 extra starters that I got in my deal and I have a chance at a CA for my Christmas present... I have no problem buying one for the CA, but since I have a bunch, it would be nice if I didn't need to. Most of them are Delco starters, and they all work.
Miles Gray (CO/KS)
MNLonnie
Orange Level Joined: 11 Sep 2009 Location: Baxter MN Points: 4790 |
The parts book shows that at tractor # B 113779 and up the starters are the same on B's and CA's. I think the only difference is that they turn the starter body 180 degrees to put the switch on top which is why CA's and newer B's have a factory dent in the bottom of the gas tank, room for the switch lever. Other than that all B/C/CA starters are the same. That's my theory.
Waukesha B, B, IB, G, styled WF, D15, 615 backhoe, 2-Oliver OC3's, 6 Ford Model T's, 3 Model A Fords, AV8 Coupe, AV8 Roadster, 1933 Ford Wrecker
MilesGray (CO/KS)
Well, after getting pictures of it; it is a C not a CA so, it looks like I will be buying a 'New' C for Christmas along with a white top Rotobaler with the original owner's manual and I will be the third owner... Go Orange!!!
Miles Gray (CO/KS)
Kip-Utah
Orange Level Joined: 14 Sep 2009 Location: Southern Utah Points: 853 |
Any starter form B,C, or CA will work on any of these tractors. The late model Bs & CAs use a different toggle on the starter switch to work by pulling the starter rod instead of pushing it. Kip |
HANSEN'S OLD ORANGE IRON. Showing, Pulling, & Going!!
Jeff Z. NY
Orange Level Joined: 11 Sep 2009 Points: 7326 |
Put a solenoid on the tractor with a key switch and they will all work.
You can get rid of the lever unless you are taking it to show and tell. Someone at show and tell will gladly point out to you that you don't have an original tractor. They like doing that for some reason I never understood. |
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
Jeff Z. NY
You may have to put a stud on them for the hot wire but that's and easy job.
JohnCO
Will one of Miles starters work on an RC? If so, Miles, whatdaya want for a starter?
Allis Express participant |
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3893 |
The CA's f4rom 1955 and later use a differant starter. the drive gear is alot smaller.
MilesGray (CO/KS)
JohnCO... Clean out your pm box.
Miles Gray (CO/KS)
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9273 |
Miles the late starters have the switch on top and the early B's have them on the bottom. The starters have a dowel pin that keeps you from rotating the head 180 deg. I drilled a new hole for mine and made it work for my late model B. It should work fine for a C.
JohnCO
Will do.
