Penetrating oil |
WC Fields(N_ILL)
Bronze Level Joined: 12 Sep 2009 Location: Rockton, ILL Points: 39 |
Posted: 16 Sep 2011 at 7:19am |
A friend has a stuck engine and I've seen on the forum a recipe for home made penetrating oil. I believe it was made with transmission fluid and acetone, correct me if I'm wrong. Does anybody know the ratio of the two or the recipe so to speak? Thanks!
37 WC 49 WF 53 WD 67 D15
studetom
Bronze Level Joined: 06 May 2011 Points: 42 |
International lubricants makes a product called Fre-eze. Really works well.
Bob D. (La)
Orange Level Access Joined: 12 Sep 2009 Location: Louisiana Points: 25529 |
50/50acetone ATF. HTH God Bless.
sparky
Orange Level Access Joined: 13 May 2011 Location: So. Indiana Points: 1463 |
A chemist friend of mine on the American Longrifle forum gave me this recipe that works REALLY well......Equal parts acetone,kerosene,ATF,and turpentine. Good Luck!!
427435
Orange Level Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Or just get a few cans of PB Blaster.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Gerald J.
Kroil often beats PB Blaster. And the ATF/acetone mix often beats both, but it also eats spray bottles. The original article on the mix didn't specify which ATF and the picture shows another oil container.
Gerald J. |
Greg (Hillsboro, OH)
Orange Level Joined: 11 Sep 2009 Location: Hillsboro, OH Points: 1163 |
This was from an OLD post on this site
Oil test posted on another site.
Penetrating Oils Compared Machinist's Workshop magazine actually tested penetrants for break out torque on rusted nuts. Significant results! *They arranged a subjective test of all the popular penetrants with the control being the torque required to remove the nut from a "scientifically rusted" environment.* *Penetrating oil ..... Average load* None ..................... 516 pounds WD-40 ............. 238 pounds PB Blaster ............. 214 pounds Liquid Wrench .. 127 pounds Kano Kroil ............ 106 pounds ATF-Acetone mix....53 pounds *The ATF-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone* *Note the "home brew" was better than any commercial product in this one particular test. A local machinist group mixed up a batch and all now use it with equally good results. Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.* |
Brian Jasper co. Ia
I wonder where BG's In Force would fit on that list. I don't like PB or WD40 because they evaporate and leave things a little sticky. BG doesn't do that. |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29661 |
I like Kroil but I also like PB Blaster, seem to be very similar. As to stuck engines, in the seventies we used Rislone, poured it directly in cylinders and let it set, took a few days but a little patience and the engines would just come loose, it breaks rust and carbon deposit bonds to the piston and cylinder walls. Have not had the need to use it for some time.
Edited by DMiller - 16 Sep 2011 at 12:00pm |
Leonard
Orange Level Joined: 06 Nov 2009 Location: Deer Park, WA Points: 558 |
For breaking loose bolts and the like I use a product by Dodge. It's the best thing I have found. i haven't tried it on a stuck engine yet. But for getting bolts and the like loose this is the product to use. It is kind of expensive at around 7-8 bucks per can.
Leonard
DaveKamp
For freeing stuck engines, I mix a 3-way of acetone, diesel/kero, and hydraulic fluid... my ace-in-hole, is a quartet of sparkplugs that the cores have been busted out, and some 1/4" pipe nipples welded to 'em... with quick-disconnects to a 4-way manifold and a pressure regulator... I put anywhere from 4-15psi on all four cylinders, but first I pop the head off, vacuum out any crud, usually take an abrasive-impregnated nylon bristle brush on cordless drill to the cylinders to break any crud free, vacuum it again, clean and lap all the valves, grease the head gasket and put it all back together with the rockers loose (valves all closed)... then I let air pressure 'help' the oil get down through the rings. It's the best tactic I've found for most 'stuck-from-sitting' situations, especially on sleeveless engines and stuff that's just plain old unobtanium. When you pull the dipstick and smell acetone, you know it's workin' it's way through.
dave63
Orange Level Joined: 01 Feb 2011 Location: Lineboro Md Points: 2382 |
Does anybody use Yield? It is very expensive but I have seen it do amazing things.
The universal answer to all questions is yes, how much do you want to spend?
Chris/CT
Orange Level Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
I'm sold on the 50/50 Acetone/ATF. Put stuck parts in pan last night, early AM they were free like new. I will try the other formula for testing.
JC-WI
Orange Level Access Joined: 11 Sep 2009 Location: wisconsin Points: 33660 |
Seems we discussed the best penetrant oil issue before but I don't find it in search. And
here is my dilemma, I bought a box of stuff at an auction a few years
back and there was an old can of PRESTO - NUT AND BOLT LOOSENER in the
mess..,. I have used it lot and seemed almost like magic to get things
loose tho there were some things that ended up getting twisted off but
most of the time it was fantastic stuff. I can not find it in google
search or amazon or ebay... did find a one google search from germany
but sure did not look like my old can... 19 OZ of the stuff. Here is a pic of my can, does anyone remember this stuff? label is pretty faded and frayed. back side says something like something... Chemical Company, ???YWOOD ?? ?1605 Did some search on best penetrant oil and got this... At $25.82 for 16.5 OZ. OUCH!
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4419 |
Personally, I think Kroil is the best, but it is expensive.
Acetone/ATF works ok, but there are two disadvantages. It separates (Acetone settles to the bottom) and the acetone evaporates quite quickly if it is left out in the open. Evaporation isn't a problem inside a cylinder when you use a spark plug or an air fitting. I use PB Blaster for most stuff, unless it's something that I think is going to be really tough, then I use Kroil. I just bought a case of Kroil (12 cans). It should last me the rest of my life.
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11565 |
I got two B engines unstuck with Kroil. And the one engine was stuck pretty tight! Had the heads off of both engines and sprayed a heavy dose in each cylinder around each piston and let it go for a week on the one engine and two weeks for the other engine. Used it through my whole WF about week prior to disassembly. No broken bolts! Couldn't believe it! Just kept spraying all the bolts when I was by it during the week prior to taking it apart. Kroil seems to work great for me...
Steve@B&B
john(MI)
If I remember correctly from the original post on the 50/50 mixture, it would not work with synthetic ATF.
HoughMade
Orange Level Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 691 |
For breaking loose an engine stuck because of rust on the cylinder walls and likely the rings, I did something crazy. I used a substance that removes rust. Evapo-Rust.
2 months of everyone's grand pappy's home brew for a week or more at a time did nothing. With the head off and the drain plug pulled, I filled up the 2 rusty cylinders with Evapo-Rust. The rust was gone and the engine was free 2 days later.
1951 B
ACinSC
Orange Level Joined: 16 Dec 2015 Location: South Carolina Points: 2579 |
We had WD-40 , Yield , Kroil , etc at work . Maint guys all seemed to prefer Kroil . Hard to find around here but I recently did . Think it was about $12 for a 10 oz spray can . Thanks !!
Gatz in NE
Orange Level Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1033 |
this came up when doing a search for NUT AND BOLT LOOSENER; (might be the same product as PRESTO; it may have been bought by TERAND) I think the price of $130 is for a case of 12 which doesn't sound too bad, but if you order it, make darn sure.I've used the 50/50 mix of Acetone and ATF for quite a while with good results. If you keep it in a plastic dispenser bottle with a thin spout, the acetone doesn't evaporate out. sample; https://www.walmart.com/ip/Unique-Bargains-Lab-Right-Angle-Tip-Plastic-Liquid-Storage-Squeeze-Bottle-Dispenser-250mL-3-Pcs/881892438 Edited by Gatz in NE - 22 Jun 2020 at 5:38pm |
WF owner
If you put acetone in a plastic bottle, it won't evaporate; it will eat right through the plastic bottle.
Gatz in NE
Curt, the mix has been in a plastic bottle for over 2 years; no problems
1947WC
Silver Level Joined: 11 Dec 2015 Location: Wisconsin Points: 214 |
I will stick with JB 80.
dawntreader74
Orange Level Joined: 28 Oct 2013 Location: Manteno Points: 1758 |
a few cans of coke' will eat that rust quick. worked when nothing else did.
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11400 |
Definitely NOT true. We've had a squeeze bottle of pure Acetone in the lab for 10 years now. SOME plastics, probably, Styrofoam DEFINITELY (in seconds), but it surely can be done. |
CaseyCreek
Silver Level Joined: 03 Apr 2011 Location: L.A. Points: 332 |
Another option is to get an all-metal squirt can with a flexible metal tip. I have been using them around the farm for years without a problem. One of them is for holding my 50/50 acetone/ATF mix. I bought the cans I use at Tractor Supply, but they are probably available at lots of other places.
D17 Series III,D17 Series IV, 185
tomNE
Orange Level Joined: 13 Sep 2009 Location: dorchester, ne Points: 1218 |
I had to go to 'metal can' with my acetone and auto tranny fluid. wouldn't even last a year! best thing i found for stuck pistons in hydrogen peroxide! cheap, readily available and it's worked better then anything for me!
Tbone95
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78015 |
womens finger nail polish remover is basically acetone.... in small plastic bottles.
