Model B transmission & differential fluid question
waynem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Topic: Model B transmission & differential fluid question
    Posted: 24 Aug 2011 at 10:48pm
I want to change the trans & differential fluid on my 1939 MODEL B what is recommended? I would like to use a modern 85w140 synthetic gear lube is that ok. Do i have to put in a posi traction additive is it a posi traction rear end in there? I have changed the motopr oil & filter & plan on flushing & filling the radiator are there any more fluids I should change or basic maintainance I should do. I dont know the last time anything has been done on my tractor. As always thanks in adsvance for all your help.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2011 at 11:30pm
Allis Chalmers called for straight 20 weight non-detergent but I think most guys use hy-tran now. I put 20 weight in my B. If your tractor has hydraulics then the trans/diff oil is where the hydraulic pump draws oil from, which is probably why AC specified a lighter weight oil than typical gear oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote waynem Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 7:03am
Would that be the same oil that are in the brakes? Is there oil in there I see drain dlugs.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2011 at 7:12am
Those are Final Drives, no brakes in there! Use gear oil in the final drives.
Hy-tran is 20 weight if I remember reading right.
Charlie
