Allis TL12 u joint
AC 89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 89 Quote  Post ReplyReply Direct Link To This Post Topic: Allis TL12 u joint
    Posted: 06 May 2024 at 9:11pm
Would anyone happen to know what size u joint I would need for the top driveshaft? Figured I'd ask before I take it apart. Thanks
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2024 at 9:16pm
If you can post measurements and a photo of the joint, I can probably tell you from my books.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 89 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2024 at 9:21pm
Ok
Edited by AC 89 - 06 May 2024 at 9:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 89 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2024 at 9:27pm
Ok I'll send you a picture tomorrow. My phone is not working. Bad service
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 89 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 4:01pm
I've tried posting a picture but my phone isn't letting me
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 4:40pm
picture is not going to help... u-joints are specked by the bearing cap OD and the WIDTH from one edge of the cap to the other.... ... Probalby 20 different sizes or more... get those numbers and you can cross reference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 4:48pm
Edited by steve(ill) - 07 May 2024 at 4:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 89 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 6:01pm
Ok I'll take it out and do some measuring. Thanks
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 7:22am
I have a new one in a box can give part # tonight if i can remember
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 89 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 7:37am
Sounds good! Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 10:26am
is this the older tl12 or the later with square front and dump cylinders on loader arms?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 89 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 10:34am
Later with a d17 motor
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 11:06am
they had d17 motor since 57.  update came about 1960
joint i have would be for loader in top video.  its a 58' i believe and had d17 engine
Edited by CAL(KS) - 08 May 2024 at 11:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 89 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 2:10pm
It looks just like thr one in the second video. It's also orange was that a optional color? Or is it supposed to be yellow? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 6:06pm
Ok that is the second style TL-12. Mine is first style. Front and rear universal joint I have is 230-0115. May not be the same for you
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 6:24pm
this is CALS u-joint... early model
Edited by steve(ill) - 08 May 2024 at 6:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 89 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 6:28pm
Mine looks just like that with the caps that bolt over the yoke. I haven't gotten the machine yet that's why I asked if anyone would know what u-joint it would need. I'm getting it this weekend.
