STARTER FOR 185 ALLIS CHALMERS
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: STARTER FOR 185 ALLIS CHALMERS
    Posted: 01 May 2024 at 5:12pm
Replacement starter for 301 diesel with turbo in Allis 185 tractor - brand and part number.
Is there a gear reduction starter that will turn the engine over faster than the original starter that you are using.
cw and number of teeth on drive
Edited by WD45 - 01 May 2024 at 5:16pm
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2024 at 7:18pm
I could probably help you out, but you need to help me out first. What brand Starter motor is in your Tractor? Is there an ID tag on the unit? You first have to determine what you have first. Then you can see what your options are for a replacement. Such as a GRS or high torque unit. I thought a 35MT came in those Tractors but not sure till you shoot me and ID number off the tag...... HTH
Steve@B&B
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 5:53am
DB Electrical 800-753-2242 good starters and alternators at good prices,have bought a lot from them.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 6:19am
I believe AC used both Delco and Lucas starters as original equipment on the 180/185.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2024 at 7:26pm
Either a Delco or Lucas starter was Original Equip.
 Nippondenso has replacement gear reduction units for both.
 They use different sized attaching bolts is why the need for what was original equip.
Delco replacement is #028000-6780.
Lucas, sorry but I don't have the number at hand.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 9:35am
My 185, and 6080 for that matter, both have Lucas starters. Not crazy about that but as they say, let sleeping dogs lie! If one quits working I'll look into the Nippondenso.
