D17 Front Pump Hub |
mnjoe
Bronze Level Joined: 12 Sep 2009 Location: MN Points: 41 |
Posted: 10 Jan 2024 at 1:42pm |
Just bought the same setup as yours. The oil tank is mounted on the fender and the hydraulic controls are mounted on a post welded to the loader frame.
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1699 |
Also found more info that should be documented in this thread Tractors earlier than: D14 engine serial #149-11562/ tractor serial
#11476 and D17 gas tractor serial #15931/diesel tractor engine #104840
DID NOT leave the factory with the front pulley that has the 4-bolt
pattern for adapter hub. Page 12 of TM-328 Manual also states: "On some of the later D-15 Tractors, be sure to rotate fan to check for clearance between fan blades and hub. Bend ends of fan blades, if necessary, to provide approximately 1/4" of clearance."
www.awtractor.com
Alex09(WI)
Yes, call the number below | | | \ | / \|/
www.awtractor.com
jnicol6600
Bronze Level Joined: 02 Jul 2011 Location: Sullivan Co. IN Points: 174 |
I had my sump drilled and tapped for a suction hose and have not had any trouble not adding any capacity
Joe(TX)
That setup is what was used on the 400 and 500 loaders
gordonh
Bronze Level Joined: 04 Oct 2013 Location: West TN Points: 144 |
Hi I was wandering if the kit you have shown would work on an AC D17 with loader? And do you sell them?
oldfords
Bronze Level Access Joined: 31 Mar 2020 Location: South Dakota Points: 46 |
Can anyone tell me the gallon capacity of the tank in the left hand loader post of a 417 loader?
Alex09(WI)
The best solution would be to swap your front pulley with one out of a later D17 that has the 4-bolt pattern. That way when the 1st adapter hub wears out, replacing it will be easy.
www.awtractor.com
Joe(TX)
I also noticed that the mounting plate bolts interfered with pump flange. You could remove material on the pump flange or possibly use socket head cap screws.
JOHN N/IL
Orange Level Joined: 11 Sep 2009 Points: 584 |
alex what do you do to make it work on a d17 with an combine motor without the correct drive pully with no holes to mount pump hub?
D-15IIG65,D-17IVG67,D-17D58,620
Alex09(WI)
It appears Joe and I have been compiling the same info this year! Nice work Joe! I shall add to the previous info. Here is a picture of the D15 gas kit that I offer. The D15 kit is very close to the D17 kit, minor differences in the bolts that hold the hub on the front pulley and the length of the driveshaft. D14 shaft and D15d shaft are the same length as the D17 gas & diesel shaft as Joe noted. From what I could find, the #50 chain coupler halves are not available. The original pumps used 11/16" pump shafts with the 3/4" drivshaft. Replacement pumps have either 5/8' or 3/4" input shafts. So from my standpoint, I have 5/8, 11/16 and 3/4 coupler halves available depending on if its original pump or aftermarket replacement pump. I went with #40 chain for these kits, which should be widely available as well as the coupler halves. Except the 11/16" coupler half, which is machined out from a 5/8" half. The "V" suffixes in my list of parts signify those parts are not OEM equivilant. The 230717 bolts were a button socket head 7/16" fine thread bolt. The 230717V bolts are 7/16" fine thread hex head bolts with a small flat washer that functions the same as the button head on the original, retaining the steel sleeve bushing from working its way out of the rubber bushing. I would like to note for others that some of the replacement pumps interfere with the heads of the 1/2" bolts that hold the plate to the tractor. Just beware that it might not be a slap on and go situation regarding the pump. Better to have the original pump rebuilt if possible. |
www.awtractor.com
Joe(TX)
Here is a drawing of the Pump Mount Plate from measuring of my plate.
Joe(TX)
Here is what I put together: Shaft 414,
415 diesel, 417 and 517 70343291
Sub. Ford 194354 (¾ dia. 13
in. lg. 6 spline) Shaft 415
gas and LPG 70343285 Length? PLATE, pump
mounting 70343660 3/8 x 5 x 6 SPACER, pump
plate (2) 70343659 1
in. OD x 3 in. lg. CAPSCREW,
1/2NC x 4-1/4 (plate) (2) CAPSCREW,
7/16NC x 1-1/2 (pump) (2) NUT, 7/16NC (pump) (2) Hub Assy,
crankshaft 70570388 Sub. Ford/ NH 54C2055 Hub Capscrew
7/16 X 1 1/4 w/ taped crank pulley (4) Hub Capscrew
7/16NF X for untapped crank pulley (nuts
required) (4) Chain
coupling (#50 10 tooth sprockets) * ¾ suction
hose ½ pressure hose
Notes:
* Standard
chain sprocket with the hub machined to reduce the diameter to approx. 1.33
dia. will work. Standard chain couplings are 16 tooth and will not clear the
spacers or the bore of the plate. Chain coupling sprockets usually have ¼
longer hubs and shorter teeth. A #40 std. coupling may work but will have a
shorter life.
Fig 16 is for D series
Edited by Joe(TX) - 07 Apr 2020 at 2:24pm |
oldfords
I ordered the hub and shaft now to see if I can make it work. I am putting a 517 loader on my 1958 D-17. The loader does not have an oil reservoir, so I was wondering what others nave done or it the existing hyd reservoir will supply enough oil.
AaronSEIA
Orange Level Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2534 |
I thought I'd pass some information along for those needing it. I was in need of a crank mounted pump drive hub after mine threw it's bolts and ate itself. Bryan H in a Facebook group gave me the number of a Ford hub that he said would work. Took my chances on a $29 on on eBay. He was dead on. Bolted up perfect and is as thick as well. AC drive shaft dropped in perfect. It got me going again. They also sell the shaft if you need it too. Really cheapens up setting up a front pump or replacing the hub when it goes bad. AaronSEIA |
