Do It Yourself Weights - On a Budget Too |
Play Farmer
Topic: Do It Yourself Weights - On a Budget TooPosted: 19 Apr 2016 at 9:45pm |
I'm about finishing up the "field grade restoration" (new paint, fluids, various upgrades, etc - a decent looking work tractor) and needed some front weights.
Locally they're about as rare as hens teeth. Obviously freight is an issue if you buy them on-line. I made the weight for my D17, but they were pretty straightforward. The 7000 took a little design work. After 3-4 sketches of ideas I finally settled on the final design. Off to the metal shop for a few pieces cut and bent, then home for a bit of welding. I think it will be OK. This added about 425 lbs, total cost $175.00 and a few hours of garage fun - around $0.41/lb. If you need more weight just get the cut and bent pieces a little bigger. A few inches either way adds a lot of extra weight. About 1/2 way welded up; ![]() All welded up, lots of rebar; ![]() Before; ![]() Installed on the tractor; ![]() |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 19 Apr 2016 at 10:13pm |
Filled with concrete I suppose?
Play Farmer
Posted: 19 Apr 2016 at 10:14pm |
Oh yeah, I failed to mention that part.
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 19 Apr 2016 at 10:29pm |
nice looking tractor, shop, and pop up camper! lol
Play Farmer
Posted: 20 Apr 2016 at 7:42am |
The camper is good. We're heading out in it in about an hour too - headed to Richmond for the NASCAR Race.
On the weight, this is how it's mounted. I ran (3) bolts through the factory weight plate into the C channel, shown above, with the nuts welded on the back side. I don't think it's going to move a bit. The bolt holes you see on the side are there for lifting. I ran 1/2" eye bolts in both sides, attached a chain and used an engine hoist to lift and mount it. Worked like a champ. The installation took me about 10 minutes, working by myself. Now I just need to get the rears loaded and it should be ready to work. ![]() Edited by Play Farmer - 20 Apr 2016 at 7:45am |
macvette
Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1657 |
Posted: 21 Apr 2016 at 10:23pm |
Good job!
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2577 |
Posted: 22 Apr 2016 at 5:48am |
Sharp!!!
AaronSEIA |
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 23 Apr 2016 at 9:07am |
NICE!!
JPG AUSTRALIA
Posted: 23 Apr 2016 at 6:31pm |
very nice looking tractor and great job on the weight box.
