HD5 Question |
creeperfreak
Silver Level Joined: 10 May 2013 Location: WNC Points: 142 |
Posted: 29 Jul 2015 at 9:04pm |
How much weight can an HD5G safely carry on its back? I just picked-up a smokin deal on a Kelley B70 3-point backhoe with the intention of adapting it to fit my track-loader, but I'm concerned the 2,000 lb weight might be too much for the Allis axles and bearings.
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41204 |
It should handle it well - only problem will be to mount you will need to remove counter weights from HD5 and use a tool carrier of some type to mount onto back case .
Another problem is the HD 5 hyd pump might not be high enough pressure for hoe , the flow rate of 5 G is 32 GPM but at about 1200 to 1500 lb pressure . Rear axles on the 5 have 3 sets of bearings - outside at the truck frame - inside at case by sprocket and inside under machine - outboard of rear case . My HD4 only had 2 sets of bearings at sprocket and inside under machine and I had a AC 650 backhoe on that . Edited by Coke-in-MN - 29 Jul 2015 at 10:17pm |
creeperfreak
Thanks, Coke. Youre right about the hydraulics, Kelley calls for a min. pump out-put of 2000psi/6-9gpm. The ideal solution here would be a two section pump, but i'll probably mount a second pump to handle the backhoe.
Coke-in-MN
Another way would be to take hydreco pump and replace it with higher pressure pump - then use diverter valve or relief valve for loader frame and separate one on hoe .
OR larger cylinder bore on new hoe to work at lower pressure . |
partswapper
Bronze Level Joined: 28 Jul 2015 Location: covington va Points: 2 |
hey coke quick question on a hd5b just put all new steering clutches soup to nuts . I recently picked up a pto driven winch . wanted to try and find pto shaft assy and install before I put fuel
and and all back on. also need bearing info for the steering levers any Ideas? any help much appreciated |
Dozer
Orange Level Joined: 16 Aug 2011 Location: SW New York Points: 689 |
The bearings on the control levers should be available from a bearing supply house. I replaced mine with "oilite" bushings. I have also replaced other bearings and bushings by making them from teflon or delren.
I recently repaired a steering cylinder that I could not get parts for by making the piston seals. |
