H3 engine? |
wildbill26
Orange Level Joined: 25 Sep 2010 Location: claysville,PA Points: 534 |
Posted: 01 Jul 2015 at 5:30pm |
What engine would an h3 have? It is gas but what size?
1950 wd wide front w loader
1940 b, 1939 m crawler |
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50548 |
I believe a 149 ci, same as a d-15, series 1
chevytaHOE5674
Orange Level Joined: 21 Apr 2010 Location: DA UP, Mi Points: 260 |
I think it could also be a 160ci if its a late model H3.
Edited by chevytaHOE5674 - 02 Jul 2015 at 5:31am |
jughead
Bronze Level Joined: 14 Sep 2012 Location: TENN. Points: 39 |
how would one tell the model? serial number?
wildbill26
Thanks guys, I didn't know if it was a 149/ 160 or a 226
What shape hole is in the sheet metal where the muffler goes through?
TOM H
Bronze Level Joined: 19 Oct 2012 Location: ND Points: 43 |
The Allis Chalmers H3 gas was introduced in the fall of 1960 with an AC 149 CI motor. In 1963 at serial # 6001 it received the 160 CI AC motor. I believe the larger 160 CI coincided with the change to a dry air cleaner and an oval muffler at the same time.
Allis-Chalmers 1927 E,1928 U,1944 WC,H3,D10,D12,D14,D15,D17,D21,TT-10 Terra Tiger, 1964
AC Golf Cart, Allis Chalmers Fridges,100's of AC Literature and Ops.and Parts manuals |
Calvin Schmidt
Orange Level Joined: 11 Sep 2009 Location: Ontario Can. Points: 4515 |
Even the first H-3 had an oval muffler. The oval is 7" the same as the D-10/12 Series III.
I have serial 1105 (1960) I don't think the 160 cu.in. later H-3 had a dry air cleaner.
jughead
you answered my question mine is 10k plus thanks to all.
TOM H
I stand corrected. Sorry. I shot from the hip. Calvin is correct in that ALL H3's had the oval muffler and also the dry air cleaner was added later after the engine was upgraded to the 160. The book by Norm Swinford states that the dry air cleaner was added when the engine was changed to 160 CI but the actual parts book shows a serial # change later in 1965 when the engine speeds were increased to 1600 RPM. I have a 1966 H3 #8961 and it does have both dry air cleaner and oval muffler although the muffler on there now is round due to prior owner could only find one like that. There is a place on side of block (hard to find)that gives serial # of engine and mine also has 160 before the serial number. It has the 6 way AC blade on it. Runs great but smokes a bit.
TOM H
Here is a picture of my H3 after I built a dike with it.
jughead
would delete post but too dumb i guess
Edited by jughead - 13 Jul 2015 at 1:10pm |
jughead
one more question please the engine number on my h3is 2160 R the serial number on the unit is 10k plus would like the year model if possible thanks sorry about the blank post pushed the wrong button
jughead
any special reason no one has replied to my post. didnt think i was hi-jacking.
Dgrader
Orange Level Joined: 17 Jan 2015 Location: Newton,IL Points: 1037 |
Norm's book says the last serial number for an h3 was 9949. Made in 1967.
Ya cain't fix stupid.
jughead
oops i was told the serial number is located on the part that the dozer blade is fastened to in front of the radiator. now i am confused. dont know what is going on.
Calvin Schmidt
The serial number is located on the left side, on the torque tube or clutch housing just behind where the engine bolts in.
CTuckerNWIL
Look in the area of the white tape for the tractor number and just ahead of that, on the block, is the engine number. |
jughead
will do. going back out there today and make sure this old man didnt write down numbers wrong. getting to where i have to triple check everything i do then have a 50 percent chance of being wrong
jughead
my previously posted numbers are correct. so what ever it is i got it and i am enjoying using it. thanks to all for putting up with me and my lack of knowledge but one doesnt get to old to learn.
