Kohler Engine identification |
lwannem
Bronze Level Joined: 23 May 2015 Location: Orchard Park Ne Points: 3 |
Posted: 23 May 2015 at 9:01am |
I recently Purchased a AC Soverign Tractor That the Model and type has been eliminated. I also Cannot find The Model and type of the twin cylinder Kohler Engine is located. The engine has NO spark, so I am trying to determine exactly which model engine I have. Can anyone help me with where the emgine model No. is??? Thank You
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3294 |
flywheel side facing you look on the tin under intake manifold on the left side there is a model , spec # and sn. it is probley covered with dirt and grease DONT USE A SCRAPER because this is a tag and it will destroy the writing
lwannem
Thank You Hudco.; I looked (as you said) and found the ID plate, however the aluminum decal was completely wiped off. What genious on the part of Kohler!!!! It probably would have cost them .39 cents to make and install a permanent label, but they elected to permantly loose the identity of that motor. If I was to put some pictures of the motor on this forum, do you think spomeone could identify it? Thank You
HudCo
should be able to id also clean tag real well and use a very bright flash light because the letters may still be imprinted in but pics will help
JoeO(CMO)
Orange Level Joined: 11 Sep 2009 Location: Cent Missouri Points: 2694 |
try this link
http://www.simpletractors.com/parts/engine/sovereign.htm HTH |
