Addiction
A-Cvtx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Topic: Addiction
    Posted: 19 Mar 2015 at 8:44pm
Bought this little jewel from Illinois. I need to pick it up and get her home!!
Insanity is relative. All of my relatives are crazy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2015 at 10:02pm
Now there's attitude right there! My kinda Tractor. Looks like its sportin' a set of 26x12x12's out back. Nice snow blower. Looks like she's ready to work. Good luck with her. Looks great!!  Love them 700 series to!
Steve@B&B
Dgrader View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2015 at 10:57pm
I bought a 712s this winter too. Mine didn't come with a snowblower and don't really want one. Where in IL. did ya get it?
Ya cain't fix stupid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2015 at 9:16am
Cooksville, Dgrader. Thanks Steve in NJ! I really don't need snow blower here in NC. Gonna see if it works well, maybe sell it next winter. Yes! 26X12X12's!! Also, stock wheels and tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2015 at 9:20am
Unless I can use the blower for leaves!! LOL!!
Ethan Souerdike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ethan Souerdike Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2015 at 10:48am
nice find  Handshake
Women will never be equal to men until they can walk down the street with a bald head and a beer gut, and still think they are sexy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2015 at 11:37am
Cut the auger off and add a set of flails on the shaft. Then enclose all but maybe a 3 inch gap at the bottom front of it and I'd bet it will chop and blow leaves, Wink You could even add a longer chute to blow them in a trailer wagon. Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2015 at 9:00pm
Tuck, I've got 3 big gum ball trees in my yard. Ya reckon your adaptation would work for gum balls?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2015 at 12:47pm
I don't know for gumballs. Maybe you need a dispenser.
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2015 at 5:05pm
HAHAHAHAHAHAAAAAA!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dgrader Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2015 at 6:02pm
Maybe I do need a dispenser.
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2015 at 8:45pm
Charlie Tucker : You have too much time on yur hands!  Better make one o' them impellers for a blower so u can refine it 'for u patent it!
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2015 at 7:45am
I have a snow thrower like that for my 917. It works great, never plugged it. I believe it would even move water.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2015 at 6:34pm
Dusty
How is the belt supposed to run? I can't get it on without a twist or jumping off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2015 at 6:50pm
On the tractor there are 2 pulleys, one of them, the one that puts spring tension, I think, there 2 holes on the strap iron that the pulley fastens to. You change the pulley to the other hole than the one used for the mower deck.
If that don't fix it I will have to check the belt routing.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 4:19am
I've watched a few Youtube videos and figured out the snowblower. From what I can see the tension pulley has been replaced with the wrong type of pulley. Now I gotta do some tests to see if the stator or the rectifier is the cause of my charging problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 9:13am
Does that have a clutch on front of motor. Some of the 700s had clutch for snow blower on front of engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 6:00pm
Yes Mikez, it does have an electric clutch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 6:05pm
Rectifier is good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2015 at 11:10pm
The one I'm thinking of isn't electric it would have a rod going up to a lever up on side of frame and look like the lever that controls mower deck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2015 at 3:51am
Not too sure about the 700 series but I know the 300-400 series had both manual and electric pto. Depending on what you bought. I just converted my 312 to manual because the electric pto was discontinued, no one could give me a part number for one that "would work" as well. I found one in Texas that was re-man for $200. The parts to convert to manual was only $40 on eBay. No brainer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2015 at 8:11am
Oh ok yeah the 300-400s had ether. If your 712 don't have the front clutch then the blower was prolly rain off the center mower clutch. Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2015 at 8:08pm
Mikez it does have the electric clutch on the front. The lever you see on the side controls the rear pto. I guess that's the one that runs tillers and stuff.
Edited by A-Cvtx - 31 Mar 2015 at 8:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2015 at 9:11pm
O wow never seen electric on 700s. Learn something new. That lever yes will do your rear stuff as well as mower deck.
The 900s they run the blower off that same clutch that the lever goes to
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-Cvtx Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2015 at 4:52pm
It may be an add on by a previous owner but it is electric.
