How do I find the PIN Holding tracts Together |
BillRO
Bronze Level Joined: 10 Sep 2014 Location: Albertville, AL Points: 18 |
Posted: 17 Sep 2014 at 10:31am |
Gargoyle
Silver Level Joined: 29 Aug 2013 Location: Missouri Points: 186 |
I'm no expert, but on mine, the master pin had a dimple in it.
It's no fun breaking the track.. Some of the guys here might give you hints.. My master pin was destroyed getting it out.. Do you have a spare? |
BillRO
BillRO
I found what looks like a Offset on one side but not the side I wont to Break
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41229 |
The master pin may have a mark on the end , be slightly longer or have other such marks or identifying features . The inner bushing in that link will also be shorter than others and have spacers on each end (and shims) to complete the link .
It is recommended to replace the master pin when removed with new > To remove a press can be used (hmm who has one setting around) or a large sludge and a friend who trusts you while holding punch for you to hit. I made up a guide to clamp to track pad to keep punch centered on pin - then the punch has rod attached to it to keep punch in guide when rebounding from sledge blows. On back side of the link with master pin you need something to keep it solid , a bucking bar of some kind so energy from sledge is now wasted in just moving the full track - I use a piece of pipe and fit that against track or track frame on other side.
If it doesnt move after you work up a good sweat trying , the outer link can be heated on both sides of track to help get pin out. The pin is not completely the same size and wear will cause part of it to be smaller so once one side is released from link it still needs to be driven through the link on opposite side . Sometimes a little oil helps when you get this far. This is where the pipe on other side also helps as does the handle on the punch. The punch I made was a 1" shaft with a 3' rod welded onto it, this slipped through the guide which was a pipe allowing the 1" shaft to slide through , this was welded to a angle iron that clamped to track . |
BillRO
Thank you Coke in MN
michale34
Silver Level Joined: 15 Mar 2011 Location: arkansas Points: 472 |
I use a railroad spike driver with a handle i put it against the pin and hit the spike driver with a sledge 2 people of course taking turns hitting like coke said sometimes heat will help if someone has removed it before they may have welded it i ran into this a few weeks back
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29739 |
Being as I work pretty well by myself I have had to engineer a few helpers. I found some steel pipe that was slightly larger internal diameter than a stick of cold rolled I had(1 1/4"), welded it to a steel plate with spacers to hold it off the inside of a track shoe then set the cold roll in it to hit with a twenty pound sledge. So far all the rails I have seen and master pins I have for my Allis have a drilled or machined 'dimple' on the end flats.
There will be only one master pin for either side. |
HD6 Merv
Silver Level Access Joined: 03 Aug 2010 Location: New Zealand Points: 476 |
Brute power from a big man with a big hammer !! sweat and swearing will happen by itself !! Jacks and heat help too.
Only time its easier is when its in a nice dry shed; but the big man and big hammer are still needed too. Good luck. master pin always has a dimple in it |
tits tyres and tracks
they all cost you money |
Randaleky
Silver Level Joined: 17 Aug 2011 Location: belfry, ky. Points: 427 |
I used two all thread rods 3/4 inch with nut on each end, two steel plates 1 inch thick, shot holes through each plate for the all thread rods and used a bottle jack to press the pin out. a little heat and they will pop out.
Coke-in-MN
Doesn't make a difference which way you remove the pin - it's just easier to get to from outside area . It may be marked only on one end
