HD6 Trans and final drive lube |
Detrot1
Bronze Level Joined: 29 Mar 2024 Location: Ky Points: 3 |
Posted: 29 Mar 2024 at 1:36pm |
I saw in here somewhere that said you could use hydraulic oil everywhere but the crankcase?
My manual said SEA 50 above 32 degrees SAE 30 below 32 degrees. CAN I run hydraulic oil in my trans and final drive? SAE 50 is 200 dollars for 5 gal. Will need 11 gals according to my manual. 5 in trans 6 in each drive. What are your thoughts? |
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3752 |
80-90 would be better for trans and bevel gear compartment. can run in finals also
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78355 |
I will not give a recommendation because i dont know.. But "MOST" hydraulic oils are in the 10 - 20 - 30 viscosity range..
50w engine oil is comparible VISCOSITY WISE to 80-90 gear lube or ISO 150 - 220 industrial gear lube... Edited by steve(ill) - 29 Mar 2024 at 2:57pm |
AMAZON....
Detrot1
Thank you for all of your replies.
I will stay with SAE 50. I didnt think it was a good idea, and couldn't find the post I saw. While the hydraulic oil would be convenient, it would just not be best for this application. Thank you all! Edited by Detrot1 - 30 Mar 2024 at 6:33pm |
Codger
Orange Level Joined: 23 Dec 2020 Location: Illinois Points: 1855 |
This product works well in Roadranger transmissions both older, and newer.
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41258 |
I used Mobile DTE - Extra Heavy grade in transmission as it also lubes the ring and pinion area . It is 1100 Sabol Second Universal grade (pour rate) which is 50 weight or slightly heavier
In finals a heavier oil like the 90 or 120 weight gear oil Edited by Coke-in-MN - 30 Mar 2024 at 8:14pm |
Adrian
Bronze Level Joined: 26 Apr 2022 Location: New Zealand Points: 4 |
If the oil in the final drives is to heavy it won't get through to the outer bearings. I think it's easier to use that right grade than replace final drive bearings later.
Coke-in-MN
the outboard bearing on axle is a link belt roller bearing which is suppose to be lubed by rifle drilling in axle - seen a lot of machines where that housing is drilled to install a grease zerk in casting , drilling where the flat raised area is . Then using gun grease to lube it
