Transmission lockup when shift plate is installed
Don kissler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don kissler Quote  Post ReplyReply Direct Link To This Post Topic: Transmission lockup when shift plate is installed
    Posted: 02 Dec 2023 at 10:22am
New to the forum. I bought a Allis Chalmers CA at the auction. The note on the tractor stated, "locked up in second gear". I removed the side shift plate and was able to put the tractor in neutral very easily with my finger. The gears look fine. When I reinstall the shift plate the transmission is locked after each attempt. I saw where someone recommended putting every thing in reverse and then reinstall the shift plate. That did not work either. An inspection of the shift looks normal. Could the shift paddles be bent? No sure how to fix this. I'm stumped!
This page was generated in 0.016 seconds.
