ELECTRONIC IGNITION |
Post Reply |
Bigrigger
Bronze Level Joined: 11 Dec 2011 Points: 42 |
Posted: 12 Mar 2012 at 5:34am |
I have a D-17 that I'm considering putting an electronic ignition in. I was wondering if anyone has had any experience with them? Do they work well? Do they last? Anyone not like them? Appreciate your input.
cwhit
Orange Level Joined: 12 Sep 2009 Location: Sigel IL Points: 963 |
We have elect. ign. on 2 tractors around here. I wouldn't go back to points- cond. ever again.
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11503 |
We sell and install quite a few of the Pertronix E.I.'s. Quite often when a customer wants his Distributor rebuilt, he or she asks for us to install an E.I. We carry the 6VPG kit, the 12VPG kit, and the 12VNG kit in stock for the Delco Distributors. Also carry some of the other popular kits for IHC etc in stock. Overall, they are a nice upgrade to the older point Ignition systems. Quicker starts, equal amount of current to each spark plug. And quite realiable. Optional high voltage coils are available also which we keep in stock, although they are designed to work with the OEM system components. Just remember tho, if you ever have to charge the Battery in your Tractor, disconnect the Battery. You could easily spike the module and blow it out with a Battery charger or jump starting it. Other than that, as I said, a great upgrade... HTH
MACK
Go to a MSD. Points will wear out rub block befor they burn up. Plugs will last almost indefently. Voltage from charger won't hurt them. MACK
Brian Jasper co. Ia
Orange Level Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
I have had a Pertronix unit in my CA for many years. Liked it well enough I got one for my Oliver 60 too. I also got their matching Flamethrower coil to ensure compatibility. I opened the plug gaps to .045 and both tractors start and run better than they ever did before.
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3892 |
I put a Pertronix in My 1968 Corvett 15 years ago. and I haven't touched it since. I got tired of fiddeling with the dual points setup evry time I took it out of storage. since putting the pertronix in I haven't touched it. starts better and I no longer have a high speed point float. Idles great and pulls strong all the way past redline. I keep saying I want to put one in my WD45's but the points just keep on working.
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21318 |
Steve's comment about being able to blow them up is why I will not buy them.Mighty d**n silly that for less than a buck, they can be made 'bullit proof', but seems no one does.Yes, they do work but having been an Avionics tech, PC repair, Industrial tech,as well as design my own remote energy systems, I have to shake my head as to WHY they 'cheap out' on an otherwise fine product.
Richard
Silver Level Joined: 12 Sep 2009 Location: Springfield, IL Points: 198 |
I put a unit in my 45 from Genesee Products a number of years ago and haven't touched it since. Engine runs super smooth from idle to wide open. Replaced the coil as well. I've had good luck with it. I asked the man before I ordered it if they had any returned. He advised if it worked past 4 or 5 hours it would likely work for years. I have no regrets.
j.w.freck
Orange Level Joined: 16 Sep 2009 Location: karnack texas Points: 1153 |
got petronics on all my 45,s.opened the points to ,040,all work great...
Bigrigger
Appreciate all the info. I had put new points in the D-17. For some reason the plastic is wearing out against the disributor shaft, and the point gap keeps closing. This was after only a week of running it. I was concerned it would wear down to the rivets and, ground out. So I figured I'd put an EI in it. I wanted to know if guys were happy with them since I've never used one before. Thanks again.
Steve in NJ
Grab a hold of the rotor and see if you can rock the main shaft back n' forth. If it moves more than .002-.005" the Distributor needs a rebuild. Shouldn't wear the rub block out in week. You'll need to get it done so you can install the E.I. and not have any problems with the magnetic pickup on the E.I.
Bigrigger
Thanks. Who's got them for sale?
mlpankey
Orange Level Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
I don't like the petronix . I do like as Mack said the msd . I also like the chevy Hei distributor converted to fit the allis. |
Kip-Utah
Orange Level Joined: 14 Sep 2009 Location: Southern Utah Points: 852 |
All of our tractors run mags except for one WC and we do run the Pertronix upgrade in that one. It has worked great for over 4 years. Had a bad starter for a while that needed lots of jumps/battery charger boosts until we wised up and replaced it. Never did disconnect or isolate the battery from the ignition circuit when charging, and ignition switch got left on a couple of times long enough the coil was hot enough to blister your hand, but the EI module is still carrying on like the Energizer Bunny! Steve's advice to disconnect battery before charging is wise advice. Kip
Steve in NJ
We do Distributor rebuilding, recurving, and restoring. Have an exchange program on them also. Can also install an E.I. in the Distributor for you if you want, if your's needs rebuilding. Drop us a line. customcircuits@gmail.com
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5620 |
+ on the Pertronix- use the right coil, and if that bushing is worn, give it a basic overhaul, clean up the weights and pivots, and it'll be good for another 55 years and-then-some.
Post Reply | |
