Unofficial Allis Homepage
D17 gas thermostat
orange-is-power View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Topic: D17 gas thermostat
    Posted: 19 May 2012 at 11:07pm
Should it be 160 or 180 degrees? I assume the WD45's will be the same? Thanks.
Gerald J. View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 11:33pm
160 for alcohol antifreeze, 180 for permanent antifreeze, like ethylene glycol.
Gerald J.
Ky.Allis View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 11:49pm
I just replaced mine with a 160 thermostat. Also installed new temp gauge. The old one was 180 and after using the tractor for several days making hay,the gauge goes up to about where it always did-about 180. I wonder why some dumb a#s at AC decided to put  three 1/4" bolts in thermostat housing? All three twisted off on mine.
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 6:51am
So is the modern antifreeze you buy off the shelf, like Prestone at Wal-Mart, considered alcohol or permanent antifreeze? That's what I'll be using. NAPA has a choice of 160 or 180 degreee thermostats and I wanted to be sure I got the right one. Thanks again.
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2012 at 7:16am
permanent
Lena 1935 WC12xxx,1938 B2xx, 1950 WD, Willie 1951 CA6xx Dad bought new, 1954WD45 PS, 1960 D17 NF
