allischalmers forklift |
Post Reply |
avbc
Bronze Level Joined: 30 Sep 2011 Location: canada Points: 5 |
Posted: 30 Sep 2011 at 2:02pm |
Hi there guys I"m new on here I have an old Allischalmers forklift it is smoking really bad I need to know what engine is in it casting # 4515827 from the engine let me know if anybody knows thanks
peter hobbit
Bronze Level Joined: 30 May 2011 Location: New Zealand Points: 10 |
Hi there is it possible for you to post some pics of your F/L According to my record Allis Chalmers intered the F/L world when they took over the Buda Company in 1953 and gained the benefitsof Budas prior work.From there they these models During the early 50s they made model F ,1957 model FT -100 ,available in 2000-6000lb
Then model FS 6000 8000 10000 lb
1965 the F-50 was built with a gangplank on it.
From the they built tractor type machines with forks on them
I may be able to help you further once I see which F/L you have
Hobbit out
avbc
the tag on it says model fp55 type g
avbc
also there is a number stamped into it on the back of the engine 2192
peter hobbit
I am unable to trace these numbers in my book ,but a photo would help
pete
avbc
please send me your email address so i can send you pics I can't send pics on here or don't know how
peter hobbit
hobbit@slingshot.co.nz
avbc
i need to know what engine it is so that I can order parts
Calvin Schmidt
Orange Level Joined: 11 Sep 2009 Location: Ontario Can. Points: 4515 |
I just picked up an ACC 50 which has a flat head Continental (I think). A lot of the earlier forklifts had the 153 Buda engine. I have some info and may be able to help. A picture of the engine would be best.
HagerAC
Orange Level Joined: 14 Sep 2010 Location: SE MN Points: 1184 |
Ours has the FC-4 Waukesha flat head in it, i am unsure of the model # of the machine otherwise. I overhauled the engine last year, and it is an expensive engine to rebuild.
rikker
Bronze Level Joined: 20 Dec 2011 Location: Lockport,NY Points: 4 |
Hello. I am new to this forum and new to an AC Forklift with a nameplate on it that says FL40-24PS lift capacity 3700 lbs and fueled by LPG. I am trying to find out what engine it has in it. It has a Delco Remy distributor 1112602 in it and the gentleman at NAPA says that was in use between 1958-1964. It is 4 cylinder. Attached are some pictures. Any help is greatly appreciated. I am trying to do a proper tuneup. Thanks in advance.
Rick
peter hobbit
Hi There I was looking at your pics have you got the firing order correct ,your lead is maked no 4 is on no 3 plug
hobbit out
ctbowles58
Orange Level Joined: 17 Jun 2011 Location: Clarksville, MO Points: 2249 |
looks like a d15 engine 149cid or 160 cid. that is what was used in the 500
rikker
You are correct, I mislabeled the leads as far as the firing order- I just put the labels on expediently from the front of the forklift(rear of the engine) so I could put them back on the correct sparkplug. Thanks for looking and replying.
Trying to find info on the engine so I can get the spark plug gap, dwell angle, and point gap. Rick
rikker
Could you tell me who made the d15 engine. I am been researching and I see Buda, Continental, and Waukesha engines were prevalent in the late 50's, early 90's. Just trying to find the correct engine electrical specs. The firing order is stamped on the engine casting- There just is no engine plate. Thanks, Rick.
Carl Ohio
Bronze Level Joined: 11 Sep 2009 Location: Johnstown OH Points: 9 |
Hi I believe that is a 4B153 Buda engine It is a wet sleeve design and parts should be avail from NAPA possibly car quest and maybe some at auto zone
hope this helps
Carl
doctorcorey
Orange Level Joined: 17 Jul 2011 Location: S. KC Missouri Points: 570 |
Hey, Rikker, is that a Massey-Ferguson hoe sitting behind the forklift?
rikker
Ooops- Posted reply w/no content.
doctorcorey- yes, it is my favorite toy - My 1966 MF 2135 industrial Tractor w/200 loader & 185 hoe. so cool of you to notice. Bought it 25 years ago from a gravedigger to dig my waterline/septic field and clear my property. 2900 hours on it and just had the injector pump rebuilt last month and now the Perkins AD3-152 diesel purrs. After getting it in perfect working order, I thought it was time to do the same to my AC forklift. Rick
doctorcorey
Cool. I've got the 203 rear half with planetary axles and the 202 front end with the 4 cyl gas Continental. Long story.....lol. They're good old tractors, and still cheap if found in "as-is" condition.
Dens71TA
Bronze Level Joined: 24 Feb 2012 Location: United States Points: 1 |
Rikker, your forklift has the Buda/AC G153 engine. I have the operator and maintenance manual for my mid-1960's F40-24 forklift which looks nearly identical to your FL40-24PS.
Tune up specs are: Spark plug gap .025 Normal Duty Gasoline Champion No. N16Y Heavily Loaded Gasoline Champion No. UN12Y Normal Duty LPG Champion No. N8 Heavily Loaded LPG Champion No. N6 Distributor points gap .022 There is a screw in plug at the base of the distributor that should be removed and the oil well topped off with SAE 20 engine oil every 500 hours to keep the distributor shaft bushing lubricated. Valve pushrod clearance should be adjusted every 500 hours. .018 cold or .015 hot. Hope this information helps. There seems to be very little information on the internet for the old Buda/AC engines. |
Forkliftrookie
Bronze Level Joined: 23 Sep 2014 Location: St. Paul Points: 4 |
Hello allis forklift gang!
Forkliftrookie
I'm new on this machine type and would like some help from the gang on where to get a maintenance manual. I don't know what type of engine I even have. It's a ACCL 40 PS forklift. Regards, Mike
carsan
Bronze Level Joined: 30 Sep 2014 Location: lubbock Points: 1 |
Hello everyone, I'm also new to this forum. So please bear with me.
We are needing a point type distributor for an AC industrial forklift model ACC45 serial AFF108648. Does anyone have a source, parts book or any info that we can use? thanx
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4340 |
Generally there is not much comment about forklifts around here.But before you give up ask on the farm equipment side of this board,as there are some very knowledgeable people over there.As well as some that have parts for sale so hopefully they will see you over there and have the parts you need.
jherkes
Bronze Level Joined: 28 Jan 2017 Location: new jersey Points: 2 |
Hi
I have this A/C fork lift 1962 that has a worn out steering bearing. I am replacing and will sell if anyone is interested .
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21442 |
The Buda G153 is the same engine as in a Cockshutt 30 tractor, Gas 153 cubes.
Phil Stier
Bronze Level Joined: 17 Oct 2009 Location: sussex wi Points: 72 |
Can anyone tell me if a FP-50 forklift is 6v or 12v??
Mike Murray
Bronze Level Joined: 24 Nov 2021 Location: Salmon Arm BC Points: 19 |
Thanks(1)
Budaenginemanualpp1thru27.pdf https://www.dropbox.com/s/1ki3npruuqif3hx/Budaenginemanualpp1thru27.pdf?dl=0 Budaenginemanualpp28thru54.pdf https://www.dropbox.com/s/fq7fmv96abnkgg2/Budaenginemanualpp28thru54.pdf?dl=0 Budaenginemanual_pg55.pdf https://www.dropbox.com/s/8ue3dg732xgsqfg/Budaenginemanual_pg55.pdf?dl=0 |
Post Reply | |
