Unofficial Allis Homepage
Allis 426 making oil!
david.bz View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote david.bz Quote  Post ReplyReply Direct Link To This Post Topic: Allis 426 making oil!
    Posted: 11 Jun 2012 at 5:27pm
hi there help needed with my 426 allis.  My engine is making oil. i cannot smell diesel and its for sure not water or coolant. It sounds like it has a miss at higher rpm. there are only 2 things i can think of. First is the fuel pump. the second is an injector gone bad. Please help. need more info please ask.
thanks. david
Gerald J. View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 5:54pm
Fuel pump is very likely. A broken diaphragm will leak fuel to the crankcase and not make full pressure to the injection pump.
Gerald J.
Edited by Gerald J. - 11 Jun 2012 at 5:58pm
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote david.bz Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 6:13pm
OK. I am looking at the rear of the fuel pump. the manual boost pump is on this section. 2 fuel hoses are connected. one comes from the tank and the othr goes to the fuel filter.  Can i instal an electric pump while i wait for a new diaphram?
albatros_3 View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote albatros_3 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 7:50pm
My Ford was doing that this spring. It had a blown seal in the pump added about 2 quarts of fuel before I caught it. I took it into a rebuild shop and had it done. One day turn-around and about an hour off and on.
injpumpEd View Drop Down
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 10:01pm
Originally posted by Gerald J. Gerald J. wrote:
Fuel pump is very likely. A broken diaphragm will leak fuel to the crankcase and not make full pressure to the injection pump.I have never seen a 426 with a mechanical fuel pump. What is this on? Help us determine the generation you're working on.
Gerald J.
MACK View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 10:13pm
I would say it has the end of a injector tip blown off. Pull injectors and have them checked.
  There is no internal driven fuel lift pump on a 426 AC engine.    MACK
JC(WI) View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 11:34pm
I think your seal on the injection pump shaft has let loose. And usually the bushing the seals ride on will be grooved too and should be replaced.
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 12:06am
It's in a Gleaner in a far away place. Good luck David. Has that got the M100 Ambach?That late of model should I think.
