Unofficial Allis Homepage
Adjusting Hydraulics on WD45
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Adjusting Hydraulics on WD45
    Posted: 20 Jun 2011 at 11:59am
I am trying to adjust the hydraulics on my 45. It has no lifting power. On step #1, you screw in the lower screw.  WHAT do you screw this into??  Then step #2  screw in to the body to separate the plates.  The only step I am having trouble with is step one. WHAT do I screw this into?  It says the body, but when I move the lever it tends to slide down.
Thanks, Ted
19?? WC / 1941 C / 1956 WD45 / 1957 WD45 / 1958 D-17
Gary in Texas View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 1:52pm
I believe they are callimg for screw "A" at the bottom , under the fram rail.
There is a detent (small hole) in the body of the housing you turn that screw into to stop the bottom lever from moving.
Bill Long View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 3:07pm
Ted,  You may want to check the pressure on your pump.  Should be around 3300 psi.  If not then it is an internal job.  May have problems with pressure release or leaking o rings valves.
In any event
Good Luck!
Bill Long
mdm1 View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2011 at 3:10pm
Ted the detent is like a small dimple in the body of the pump.
Some days all you make is sawdust! 1955 WD45-trip loader 1947 c w/woods belly mower, #3 sickle mower Misc other equipment that my wife calls JUNK!
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2011 at 11:09am
Thanks for the help guys!!  The 'dimple' was full of HARD grease and dirt.  Once I cleaned it out I readjusted everything and it works perfect now.  THANKS All.  Ted
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2011 at 11:48am
That is really GOOD NEWS!  The alternate required that you remove the pump and so some inside work.  Not impossible but tedious.
Good Luck!
Bill Long
wkpoor View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2011 at 4:41pm
That lever is the draft control and to my recalection should have nuttin to do with lifting ability. Turning that screw in just locks out the draft control.
John_B View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote John_B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2011 at 12:55pm
Have the draft control locked out on mine, but it slowly raises the lift without using the lever after a few minutes. Is this something internal?
mdm1 View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2011 at 2:23pm
You need to have everything set for lift and hold. Should be a diagram on your battery box for the different settings.
B26240 View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2011 at 4:31pm
I know there is lots of things to adjust on the pump, I tried setting the traction booster system to plow one time, I only had a 3 acre field and never did get it right. the plow was in and out like a feeding porpoise.
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote John_B Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2011 at 10:06pm
The linkage for the feedback from the snap coupler is missing, and I have dialed out the traction control and set the other adjustments acording to the manual.  But it still creeps up.
mdm1 View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 10:15am
You have to move the control lever by the steering column up and then back down. You kinda find a certain spot doing this and it will not creep up in theory. You get the knack after a few times. I just watch mine close.
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote John_B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 10:38am
wish it were that simple. I can drop it below  the lower stop but  it still happens.
mdm1 View Drop Down
Status: Offline
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2011 at 12:20pm
John try dropping the lever down alittle so the arms don't move and then bring it up some just before the arms move up.  It works on mine.
