7040 fuel problems
Matt Z View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt Z Quote  Post ReplyReply Direct Link To This Post Topic: 7040 fuel problems
    Posted: 15 Jun 2011 at 5:22pm
 I've got a 7040 that as of late when we start it, It immediately runs out of fuel. We need to pressurize the fuel system by pumping the hand pump before we start it. It then runs very good. We can see an air gap in the glass fuel filter before we use the hand pump. It fills as we pump. We have replaced the filters twice and currently have a new filter on. Has any body ever dealt with this before? Any feedback is appreciated. Thanks in advance.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2011 at 5:28pm
i,m trying to remember , i think allis came up with a  new route from the fuel tank to the filters , but this was done when our tractor was less than a year old , as we once had an issue ,  if i remember i,ll get back to you with more info ..
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2011 at 5:55pm
My 7040 did the same thing. It was sucking air in one of the lines. It never leaked fuel but there was enough of a hole in the line that air got in. I replaced all the Orings and the lines behind the fuel filter where they were rubbing. That fixed the problem, it runs like a top again.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2011 at 6:18pm
Replace the lines and you should be good did that on our 7060.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2011 at 8:53pm
Yup o- rings on the fuel lines suckin air
This page was generated in 0.039 seconds.
