190XT expert required |
Post Reply |
youngorange2000
Silver Level Joined: 27 Mar 2019 Location: eastcentral MN Points: 308 |
Posted: 15 Oct 2022 at 7:52pm |
anyone know what these two welded shut lines are for they are located in front of the passenger side brake assembly. Thanks in advance
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7231 |
Can you zoom out for a better shot? The entire hydraulic valve body is in front of the brake assembly. |
youngorange2000
This is located about 6 inches behind the main hydraulic spools and pd valve
Lynn Marshall
Orange Level Access Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2160 |
That's the PTO valve body.
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1699 |
resized picture* My best guess is someone removed the hyd pto clutch from the torque tube and capped off the lines from the pto valve. |
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
youngorange2000
Is it possible my tractor had a hydraulic pto at some time? It has a decal on the side of the counsel for the PTO but no lever it has the pull knob on the floor
Orange Level Access Joined: 12 Sep 2009 Points: 19647 |
The valve is there. So, they removed the lever.
youngorange2000
Is it possible my tractor has both types of PTO? If so why would they disable the hydraulic pto?
Alex09(WI)
For simplicity's sake, it is not possible to have both. You have 1 or the other. If you still had the hyd pto clutch, your pto would not work because there is no hyd pressure to engage it, regardless of moving the knob by the platform. The hyd pto enables the operator to engage and disengage the pto independently of the foot clutch. It is not live PTO, because you don't have to use the foot clutch to engange it. And its not really independent PTO because in an emergency, the operator can use his reflex to slam in the clutch pedal to stop all powered motion. I might label it as semi-independent pto??
www.awtractor.com
DSeries4
You would have to ask the previous owner why they disabled it. Only they would know.
Post Reply | |
