185 Brake Problem How Bad |
Post Reply |
NDCurt
Silver Level Joined: 25 Sep 2009 Points: 75 |
Posted: 16 Sep 2012 at 5:38pm |
Brakes on the 185 have needed doing for awhile but now the left one is totally locking up. Forward and reverse will break free for a couple feet and then lock up. Question is - how much more damage could I do if I continue to rock it free and get in the shop ~150 feet. Also, this is going to be a big job right, cab off/tilted back out of the way and then from the top? Thanks
Orange Level Access Joined: 12 Sep 2009 Points: 19565 |
When they start locking up, you've probably done some expensive damage already and more use means more $$$$$$ damage. Depending on the cab design, you have to be able to remove the complete axle from the rear end.....nothing from the top.
Marshall
Bronze Level Joined: 30 Mar 2010 Points: 22 |
The steel panel around the seat base is handy to have off if you have brake pins that are difficult to drive out. On my tractor, one brake band pin slid out easy, but the other side took several hours of work before it freed up. I ended up needing the seat access panel removed so that I could cut the pin and brake band from the top. You will hate the design if you get one that is tuff to pull. A pin having 1-7/8 of solid tight tolerance steel to pass through is not my idea of a good design plan. Thats probably the worse part of the whole procedure of changing brakes. That and having to move the hydraulic bank up and out of the way to pull the axles. Good Luck!
Stubborn Brake Band Pin :( A Last minute "throw together" axle hoist. Worked very well! Edited by Marshall - 16 Sep 2012 at 9:29pm |
NDCurt
Thanks for the good info - Not what I want to do right now got about 40 bales of hay to bale and haul that I really want done and this is not an overnight project.
Gatz in NE
Orange Level Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1033 |
Curt,
I've got some pics from when I replaced the brakes on my D17sIV; which would be similar to a 185. PM me if you need them. gatz |
NDCurt
Well I got lucky, after I got the cab jacked up high enough to get at the axle bolts everything came apart real easily. Brake band linings look like new (almost) but all the other pads are shot. The worst is that the balls between the drum and disc assembly had come out of their spot so drum and other part are shot also. Parts will be here Friday so I guess I know what the weekend will be.
Gatz in NE
if you havent read about it before..... do NOT lube the balls/ramps when assembling.
Eldon (WA)
Orange Level Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
ALLIS EXPRESS!
This year: |
Eldon (WA)
ALLIS EXPRESS!
This year: |
You do what you want with/without lube on the balls...I don't care. You'd better be using some light lube/WD40 etc on the splines of the drum to the axle shaft, so the drum can slide easily back and forth.
NDCurt
Well, parts came today and things went together a lot better/easier than I thought they would, had it back together in a couple hours. I had done the same thing to my 180 a number of years ago but I had the shop do it. Sure saved a bundle doing it myself and not having to haul it in. Thanks for all the advice.
Post Reply | |
